قائمة فحص اويل سيل Seal Installation Checklist
يضم كل ما يخص عمليات الصيانة سواء صيانة ميكانيكية او كهربائية قسم الصيانة الميكانيكية و الكهربائية - Mechanical & Electrical Maintenance Section
مشاركات: 8638
*Seal Installation Checklist*
*قائمة فحص اويل سيل*
❏ Is the seal in good condition?
❏ Is the spring properly in place, or has it been displaced during handling?
❏ Have you carefully wiped the seal clean (so as not to damage it)?
❏ Have you made sure there are no nicks, scratches, or spiral grooves on the shaft surface?
❏ Have you pre-lubricated the seal’s lip for initial break-in?
❏ Are you installing the seal with the lip facing in the right direction?
❏ Are you installing the seal at a right angle to the centerlines of the bore and shaft?
❏ Have you made sure that bore adhesives do not contaminate the shaft or seal lip?
❏ Have you taken measures to keep the lip from being damaged by passing over
splines, threads, or burrs on the shaft?
❏ Have you inspected the bore to make sure there are no burrs or scratches?
❏ Have you ensured proper protection for the seal during painting or cleaning operations?
❏ Is adequate ventilation provided for internal pressure in the seal area?
❏ Have you made sure that assembly components do not rub and that any vents are not clogged?
*بعدها يتم معرفة هل الاويل سيل هذا صالح للاستخدام او يمكن الاستمرار فى استخدامه ام لا*
العودة إلى ”الصيانة الميكانيكية و الكهربائية Mechanical & Electrical Maintenance“
