what could be the reason for rollers shaft breaking frequently in a flour mill أسباب كسر أكس درافيل الطحن ؟
what could be the reason for rollers shaft breaking frequently in a flour mill.
ما يمكن أن يكون سبب كسر عمود / أكس الرولات / درافيل الطحن بشكل متكرر في مطحنة الدقيق ؟
كسر عمود درافيل الطحن
كسر اكسات الدرافيل الليس
This smooth rolls are out of order but the shaft breakage trend is the same.
https://www.linkedin.com/posts/koga-david-john-1b3a4096_what-could-be-the-reason-for-rollers-shaft-activity-7009579465055858689-X81x?utm_source=share&utm_medium=member_desktop
dear most probably miss alignment and bearing house positioning
Make sure if you're buying a branded bearing (which you're supposed to do) you buy them from a trusted supplier, nowadays, even the branded bearing in the market either they're renewed (secondhand) or they're counterfeit goods, the correct lubricant is used (ask your machine manufacturer for the lubricant specification), while running, frequently check the bearing and rolls temperature (recommended every shift) to monitor and tackle the problem before reaching to the bottleneck.
You have to also check vibration analies
Roll adjustment uneven,Rolls are not barrel,
Alignment, bearing and the type of grease is not suitable for the application
Check your sprockets and compare if their diameter still goes alon with the diameter of your rolls. If using refluted rolls, you will have to use smaller sprockets as well. Otherwise you have tension in the sprocket box which would explain the breakage.
Dear check roller alignment and bearing adjustment
