لماذا السرعة ذات الاتجاه velocity أهم...ركز على السرعة ذات الاتجاه، لا السرعة فقط ... Slow is smooth, and smooth is fast
مشاركات: 9033
The best advice I’ve ever received:
Slow is smooth, and smooth is fast.
Why velocity is more important than speed.
You’re fast.
You’ve got speed.
Awesome. Good for you.
But ask yourself, where are you going? What’s your direction?
Speed is only useful if you have a compass to guide you:
1. Velocity = Speed + Direction
Where you go matters just as much as how fast you go.
There is nothing worse than sprinting ahead only to find out you’ve been going the wrong way.
So, spend some time getting your bearings right from the start.
Sometimes, that means slowing down.
Maybe even stopping.
Take the time to reflect on your surroundings. Does it look anything like your ideal life? Does it align with your inner self? Adjust if the answer is ‘No’.
Lesson: Slow down to speed up.
2. Avoid Burnout
I learned this the hard way.
I let my first two businesses dominate my personal boundaries.
My life was 100MPH, and I’d lost track of the brake pedal.
Going fast in the wrong lane leads to founder fatigue.
Spend time getting your direction right before hitting the gas pedal.
Write down your passions and skills and focus on building leverage around those.
Don’t let the entrepreneurial rollercoaster take you somewhere you don’t belong.
Focus on steady and sustainable growth.
3. Narrow Your Focus
Being smart and hustling hard isn’t enough.
Warren Buffett knows that you need to focus your energies on the things you do best.
Narrow your focus to your zone of genius.
100 hours spent on the wrong thing is 100% of your effort wasted.
But this doesn’t mean you should lounge around.
There’s no such thing as a perfect path.
Get clear on your direction and zone of genius. Spend time on this.
Then execute.
4. Decision Velocity
Making fast decisions separates winners from procrastinators.
Writing down your interests, skills, and goals is enough data to start.
Decide with 70% confidence vs 100%.
Avoid paralysis by analysis.
5. Take Massive Action
Dream big, start small, and always act.
Take intentional strides in the direction you’ve mapped out. Daily movement compounds your progress.
The journey of a thousand miles begins with a single act.
6. Make Many Decisions
I prefer to make 100 decisions per week with 10 mistakes rather than 1 perfect call.
The only way to improve your judgment is by practicing.
Done > Perfect
7. Focus on velocity over speed.
It took me 10 years to truly internalize this advice.
Now I earn $13.8 million in passive income per year.
Find your inner compass and build your dream life with intention, not haste.
https://www.linkedin.com/mwlite/feed/posts/mattgray1_the-best-advice-ive-ever-received-slow-activity-7266459232734953474-moZx?utm_source=share&utm_medium=member_android#:~:text=Matt%20Gray,lnkd.in/ehMWgysW
أفضل نصيحة تلقيتها على الإطلاق:
البطء السلس يؤدي إلى السرعة السلسة.
لماذا السرعة ذات الاتجاه (velocity) أهم من السرعة فقط (speed).
أنت سريع. لديك سرعة. رائع.
لكن اسأل نفسك: إلى أين تتجه؟ ما هي وجهتك؟
السرعة وحدها عديمة الفائدة إذا لم يكن لديك بوصلة لتوجهك.
المعادلة:
السرعة ذات الاتجاه = السرعة + الاتجاه
المكان الذي تتجه إليه لا يقل أهمية عن سرعة وصولك.
لا شيء أسوأ من الركض بسرعة في الاتجاه الخاطئ.
لذا، خذ وقتًا لتحديد الاتجاه الصحيح منذ البداية.
في بعض الأحيان، هذا يعني التباطؤ، وربما حتى التوقف تمامًا.
تأمل في بيئتك. هل تشبه حياتك المثالية؟ هل تتماشى مع ذاتك الداخلية؟
إذا كانت الإجابة "لا"، قم بإجراء التعديلات اللازمة.
الدرس: تباطأ لتسرع لاحقًا.
1. تجنب الإرهاق
تعلمت هذا بالطريقة الصعبة.
سمحت لأول مشروعين لي بالسيطرة على حياتي الشخصية تمامًا.
كانت حياتي تسير بسرعة 160 كم/ساعة، وفقدت السيطرة على دواسة الفرامل.
الركض بسرعة في الاتجاه الخاطئ يؤدي إلى إرهاق مؤسسي.
خذ وقتك لتحديد الاتجاه الصحيح قبل أن تضغط على دواسة البنزين.
قم بكتابة شغفك ومهاراتك، وركز على بناء قوتك من حولها.
لا تسمح لدورة ريادة الأعمال أن تأخذك إلى مكان لا تنتمي إليه.
ركز على النمو المستدام والمتوازن.
2. ركز على النقاط المهمة
الذكاء والعمل الجاد وحدهما لا يكفيان.
وورن بافيت يقول: ركز طاقتك على الأشياء التي تجيدها.
قلّص نطاق تركيزك إلى ما يُعرف بمنطقة العبقرية لديك.
100 ساعة تقضيها في العمل على شيء خاطئ تعني إهدار 100% من جهدك.
ولكن، هذا لا يعني أن تجلس بلا حراك.
لا توجد طريق مثالية.
حدد اتجاهك ومنطقة عبقريتك، ثم ابدأ بالتنفيذ.
3. سرعة اتخاذ القرار
اتخاذ قرارات سريعة هو ما يميز الناجحين عن المترددين.
كتابة اهتماماتك ومهاراتك وأهدافك توفر لك البيانات الكافية للبدء.
اتخذ قرارات بثقة 70% بدلاً من انتظار الثقة الكاملة 100%.
تجنب الشلل الناتج عن التحليل الزائد.
4. اتخذ إجراءات كبيرة
فكر بشكل كبير، ابدأ بخطوات صغيرة، واتخذ الإجراءات باستمرار.
التحرك يوميًا وبشكل مقصود في الاتجاه الذي حددته يضاعف تقدمك.
رحلة الألف ميل تبدأ بخطوة واحدة.
5. اتخذ العديد من القرارات
أفضل أن أتخذ 100 قرار أسبوعيًا وأخطئ في 10 منها، بدلاً من اتخاذ قرار مثالي واحد.
الطريقة الوحيدة لتحسين قدرتك على اتخاذ القرار هي الممارسة.
الإنجاز > المثالية.
6. ركز على السرعة ذات الاتجاه، لا السرعة فقط.
استغرق الأمر مني 10 سنوات لاستيعاب هذه النصيحة تمامًا.
والآن، أكسب 13.8 مليون دولار سنويًا كدخل سلبي.
ابحث عن بوصلة داخلية، وابنِ حياتك التي تحلم بها بقصد، وليس بعجلة .
