رقم السقوط: المؤشر الصامت لقدرة القمح على الخبز ... Falling Number The Silent Indicator of Wheat’s Baking Potential
مرسل: السبت إبريل 26, 2025 11:35 am
Falling Number: The Silent Indicator of Wheat’s Baking Potential"
FallingNumber: The Silent Indicator of Wheat’s Baking Potential 🧪🍞
Behind every perfect loaf of bread or batch of noodles lies a chain of quality decisions—many of which start with a lab test that takes less than 10 minutes.
➡️ That test? It’s called the Falling Number test.
And while it doesn’t get as much attention as protein or gluten content, it plays a crucial role in predicting how wheat will behave in the bakery or pasta plant.
🔍 What is the Falling Number Test?
It measures alpha amylaseEnzyme activity in wheat or flour. This enzyme breaks down starches into sugars—and too much of it can wreak havoc on product quality.
➡️ The procedure to determine Falling Number is standardized and internationally recognized (e.g., ICC Method 107/1, ISO 3093):
1️⃣ Sample Preparation: Whole wheat is ground into meal, or flour is used directly.
2️⃣ Slurry Formation: A fixed amount of sample (typically 7g) is mixed with distilled water in a viscometer tube to form a slurry.
3️⃣ Gelatinization: The tube is placed in a boiling water bath. During this process, the starch gelatinizes, forming a thick paste.
4️⃣ Measurement: A metal plunger is dropped into the tube. The time (in seconds) it takes for the plunger to fall through the gel is recorded as the "#FallingNumber."
➡️ The longer it takes, the higher the Falling Number, and the lower the enzyme activity. A short time suggests enzymatic degradation of starch due to sprouting.
⚠️ Why It Matters
Excessive enzyme activity often indicates pre-harvest sprouting, where wet weather causes grains to start germinating on the stalk. This weakens starches, leading to:
➡️ Sticky, collapsed bread loaves
➡️ Gummy or dark-colored noodles
➡️ Unpredictable fermentation
➡️ Lower shelf life and poor texture
⚠️ Even small variations in Falling Number can translate to big shifts in product performance.
📊 Typical Ranges
➡️ >300 seconds = Good stability, low enzyme activity
➡️ 200–300 seconds = Borderline, may affect sensitive products
➡️ <200 seconds = High sprout damage risk, often rejected for baking or pasta use
⏩ Different applications demand different tolerances, but for most baked goods and pasta, a stable falling number is non-negotiable.
🛠️ Implications for the Value Chain
✅ #Millers can avoid inconsistent flour by testing wheat at intake
✅ #Bakers can reduce batch failure by verifying flour specs
✅ #Farmers can protect their crop’s marketability with timely harvesting
✅ #Foodmanufacturers can ensure product consistency and consumer satisfaction
💡 Final Thought
The Falling Number might be "just a number," but it speaks volumes. In quality control, the silent indicators are often the most powerful.
 #wheatquality #fallingnumber #grainquality #flourmilling #bakeryscience #pastaquality #foodtechnology #bakingindustry #qualitycontrol #foodinnovation #cropquality"
https://www.linkedin.com/mwlite/feed/posts/abdul-jabbar-hussain-6487911a9_fallingnumber-alphaabramylaseenzyme-fallingnumber-activity-7321665255527313408-oj7a?utm_source=share&utm_medium=member_android&rcm=ACoAABG_IYwBEFoQoeYtJNIF1NzAvC8HDe-lKJ4#:~:text=Falling%20Number%3A%20The,foodinnovation%20%23cropquality
رقم السقوط: المؤشر الصامت لقدرة القمح على الخبز ... Falling Number: The Silent Indicator of Wheat’s Baking Potential"
خلف كل رغيف خبز مثالي أو باتشة ناجحة من المكرونة، توجد سلسلة من القرارات المتعلقة بالجودة — يبدأ الكثير منها باختبار مخبري لا يستغرق أكثر من عشر دقائق.
➡️ هذا الاختبار؟ يُسمى اختبار "رقم السقوط".
وعلى الرغم من أنه لا يحظى بنفس الاهتمام الذي يحظى به محتوى البروتين أو الجلوتين، إلا أنه يلعب دورًا حاسمًا في التنبؤ بكيفية تصرف القمح أثناء التصنيع في المخبز أو مصنع المكرونة.
🔍 ما هو اختبار رقم السقوط؟
يقيس اختبار رقم السقوط نشاط إنزيم الألفا أميليز في القمح أو الدقيق. هذا الإنزيم يقوم بتكسير النشويات إلى سكريات — وزيادته المفرطة قد تُلحق ضررًا كبيرًا بجودة المنتج.
➡️ الإجراء لتحديد رقم السقوط موحد ومعترف به دوليًا (مثل طريقة ICC رقم 107/1 أو معيار ISO 3093):
1️⃣ تحضير العينة: يتم طحن القمح الكامل (طحين خشن)، أو يُستخدم الدقيق مباشرة.
2️⃣ تكوين الخليط: يتم خلط كمية محددة من العينة (عادةً 7 جرامات) مع ماء مقطر داخل أنبوب قياس اللزوجة لتكوين مزيج معلق.
3️⃣ التجلتن (تحول إلى معجون): يوضع الأنبوب في حمام مائي مغلي، وخلال هذه العملية يتجلتن النشاء، مكونًا معجونًا سميكًا.
4️⃣ القياس: يتم إسقاط مكبس معدني داخل الأنبوب، ويتم تسجيل الزمن (بالثواني) الذي يستغرقه المكبس للسقوط عبر الهلام كـ "رقم السقوط".
➡️ كلما طال الزمن، ارتفع رقم السقوط، ودل ذلك على انخفاض نشاط الإنزيم. أما الزمن القصير، فيشير إلى تحلل النشا بفعل الإنزيمات نتيجة التبرعم (الإنبات المبكر).
⚠️ لماذا يعتبر مهمًا
تشير زيادة نشاط الإنزيمات غالبًا إلى حدوث التبرعم قبل الحصاد، عندما تؤدي الظروف الرطبة إلى بدء إنبات الحبوب وهي لا تزال على السنبلة. وهذا يؤدي إلى:
➡️ أرغفة خبز لزجة ومسطحة
➡️ مكرونة لزجة أو داكنة اللون
➡️ تخمير غير متوقع
➡️ انخفاض مدة الصلاحية وسوء القوام
⚠️ حتى التغيرات الطفيفة في رقم السقوط يمكن أن تؤدي إلى تغيرات كبيرة في أداء المنتج النهائي.
📊 النطاقات النموذجية
➡️ أكثر من 300 ثانية = استقرار جيد، نشاط إنزيمي منخفض .
➡️ 200–300 ثانية = حدِّي، قد يؤثر على المنتجات الحساسة .
➡️ أقل من 200 ثانية = خطر عالٍ لضرر التبرعم، غالبًا ما يُرفض للاستخدام في الخبز أو تصنيع المكرونة .
⏩ تختلف المتطلبات حسب التطبيق، لكن بالنسبة لمعظم المخبوزات والمكرونة، يعتبر الحفاظ على رقم سقوط مستقر أمرًا غير قابل للتفاوض.
🛠️ الآثار على سلسلة القيمة
✅ يمكن للمطاحن تفادي الطحين غير المتناسق من خلال اختبار القمح عند الاستلام .
✅ يمكن للمخابز تقليل فشل الباتشات عبر التحقق من مواصفات الدقيق .
✅ يمكن للمزارعين حماية تسويق محاصيلهم من خلال الحصاد في الوقت المناسب .
✅ يمكن لمصنعي الأغذية ضمان اتساق منتجاتهم ورضا المستهلكين .
💡 فكرة ختامية
قد يكون "رقم السقوط" مجرد رقم، لكنه يعبر عن الكثير. ففي مراقبة الجودة، غالبًا ما تكون المؤشرات الصامتة هي الأكثر قوة.
