فهم منحنى الرماد عند نسبة رطوبة 17٪ – مفتاح جودة الدقيق
مرسل: الأربعاء مايو 28, 2025 1:24 pm
Understanding the Ash Curve at 17% Moisture – Key to Flour Quality
As a Shift Miller working with high-performance milling systems, one of the most critical tools I use to monitor and control flour quality is the Ash Curve — especially at a wheat tempering level of 17% moisture.
What Is an Ash Curve?
An ash curve shows the relationship between extraction rate and ash content. It helps us understand how cleanly the endosperm (flour) is separated from the bran during milling.
Simulated Ash Curve Data at 17% Moisture:
Picture attached
Key Insights:
10–60% Extraction:
Low ash values – this range gives high-quality white flour with minimal bran contamination.
60–80% Extraction:
Ash begins to increase steadily – careful process control is needed.
80–90% Extraction:
Sharp rise in ash – typically associated with bran-rich flour used in wholemeal products.
Why It Matters:
Helps set ash targets for different flour grades
Assists in milling optimization
Supports quality control and customer satisfaction
Whether you're producing fine bakery flour or whole wheat, understanding this curve is essential for delivering consistent quality.
If you're also in the milling or food production industry, how do you use ash curves in your quality strategy? Let’s share ideas.
#FlourMilling #AshCurve #FoodIndustry #QualityControl #WheatProcessing #ShiftMiller #Bühler #MillingTechnology #FoodSafety #WheatFlour
https://www.linkedin.com/mwlite/feed/posts/muhammad-haroon-79889b263_flourmilling-ashcurve-foodindustry-activity-7333353997564645376-B201?utm_source=share&utm_medium=member_android&rcm=ACoAABG_IYwBEFoQoeYtJNIF1NzAvC8HDe-lKJ4#:~:text=Understanding%20the%20Ash,FoodSafety%20%23WheatFlour
بصفتي طحّانًا في نوبة عمل أعمل مع أنظمة طحن عالية الأداء، فإن أحد أهم الأدوات التي أستخدمها لمراقبة جودة الدقيق والتحكم بها هو منحنى الرماد — وخاصة عند ضبط رطوبة القمح على مستوى 17٪.
ما هو منحنى الرماد؟
يُظهر منحنى الرماد العلاقة بين معدل الاستخلاص ومحتوى الرماد. ويساعدنا هذا المنحنى على فهم مدى نقاء فصل السويداء (الدقيق) عن النخالة أثناء عملية الطحن.
بيانات منحنى الرماد المُحاكاة عند رطوبة 17٪:
(صورة مرفقة)
أهم الاستنتاجات:
استخلاص بنسبة 10–60٪:
قيم رماد منخفضة — هذا النطاق يُنتج دقيقًا أبيض عالي الجودة مع أدنى حد من تلوث النخالة.
استخلاص بنسبة 60–80٪:
يبدأ الرماد بالارتفاع تدريجيًا — ويتطلب ذلك تحكمًا دقيقًا في العملية.
استخلاص بنسبة 80–90٪:
ارتفاع حاد في الرماد — ويرتبط هذا عادةً بدقيق غني بالنخالة يُستخدم في المنتجات الكاملة (الدقيق الكامل).
لماذا يُعدّ هذا الأمر مهمًا؟
يساعد في تحديد أهداف محتوى الرماد لأنواع الدقيق المختلفة
يساهم في تحسين عمليات الطحن
يدعم مراقبة الجودة ورضا العملاء
سواء كنت تنتج دقيقًا فاخرًا للمخابز أو دقيق قمح كامل، فإن فهم هذا المنحنى يُعد أمرًا أساسيًا لضمان جودة متسقة.
إذا كنت تعمل أيضًا في مجال الطحن أو إنتاج الأغذية، كيف تستخدم منحنيات الرماد ضمن استراتيجيتك لضمان الجودة؟ دعنا نتبادل الأفكار.
