القمح حديث الحصاد يحتاج إلى وقت كي "ينضج" اكثر من وقت الدقيق اللازم للنضج (تعتيق الدقيق)
مرسل: الخميس سبتمبر 04, 2025 10:58 pm
Freshly harvested wheat needs time to “mature”
because the gluten proteins are too soft .
Traditionally, mills store wheat for weeks or months to allow natural oxidation and enzyme stabilization before milling.
However,
once the wheat is ground into flour, maturation accelerates because:
Greater surface area
→ More oxygen contact, speeding up natural oxidation of gluten proteins (especially the sulfhydryl to disulfide bond conversion).
Enzyme distribution
→ In flour, endogenous enzymes interact more evenly with substrates, so their activity stabilizes faster.
Moisture dynamics
→ Flour has lower equilibrium moisture than whole kernels, making it easier for oxidative changes to occur.
That’s why storing flour,
even for just a few weeks, can “age” it faster than storing whole wheat.
In fact,
before chemical improvers like ascorbic acid were introduced,
mills relied heavily on flour aging to reach optimal baking quality.
BUT ❌
⚠️ Here’s the risk:
Mill tests flour on day of grinding
→ specs look fine.
Flour matures during storage
→ rheology changes.
Baker tests flour a few days later
→ results don’t match.
This gap is much more common when wheat is fresh.
If you found this helpful:
♻️ Repost + 🔔 Follow for practical, science-backed insights on dough systems, protein functionality, and bakery performance.
https://www.linkedin.com/mwlite/feed/posts/dimitrios-argyriou-1a38251b6_freshly-harvested-wheat-needs-time-to-mature-activity-7363083574679367680-byq_?utm_source=share&utm_medium=member_android&rcm=ACoAABG_IYwBEFoQoeYtJNIF1NzAvC8HDe-lKJ4#:~:text=Freshly%20harvested%20wheat,bakery%20performance.%0AGRAINAR
لأن بروتينات الجلوتين تكون طرية جدًا.
تقليديًا، تقوم المطاحن بتخزين القمح لأسابيع أو شهور للسماح بحدوث الأكسدة الطبيعية واستقرار الإنزيمات قبل الطحن.
ولكن، بمجرد أن يُطحن القمح إلى دقيق، فإن عملية النضج (المعروفة فى مجال المطاحن : تعتيق الدقيق) تتسارع للأسباب التالية:
زيادة مساحة السطح
→ مما يؤدي إلى زيادة ملامسة الأكسجين، وبالتالي تسريع عملية الأكسدة الطبيعية لبروتينات الجلوتين (وخاصةً تحول مجموعات السلفهيدريل S-H إلى روابط ثنائية الكبريت S-S).
توزيع الإنزيمات
→ في الدقيق، تتوزع الإنزيمات الذاتية بشكل أكثر تجانسًا مع ركائزها، وبالتالي تستقر فعاليتها بشكل أسرع.
ديناميكية الرطوبة
→ الدقيق له توازن رطوبي أقل مقارنةً بحبوب القمح الكاملة، مما يسهل حدوث التغيرات التأكسدية.
ولهذا السبب، فإن تخزين الدقيق حتى لفترة بضعة أسابيع فقط يمكن أن "يُعجِّل" عملية النضج أكثر بكثير من تخزين القمح الكامل.
وفي الواقع، قبل إدخال المحسنات الكيميائية مثل حمض الأسكوربيك،
كانت المطاحن تعتمد بشكل كبير على عملية "تقادم" أو "شيخوخة" أو تعتيق الدقيق للوصول إلى الجودة المثالية للخبز.
❌ ولكن
⚠️ هناك مخاطرة:
المطحن يختبر الدقيق يوم الطحن
→ المواصفات تبدو جيدة.
الدقيق ينضج أثناء التخزين
→ تتغير الخصائص الريولوجية (سلوك العجين).
الخباز يختبر الدقيق بعد عدة أيام
→ النتائج لا تتطابق.
وهذا الفارق يظهر بشكل أكبر عند استخدام القمح الطازج.
Re: القمح حديث الحصاد يحتاج إلى وقت كي "ينضج" اكثر من وقت الدقيق اللازم للنضج (تعتيق الدقيق)
مرسل: الخميس سبتمبر 04, 2025 11:02 pm
🔹 معنى نضج الدقيق أو تعتيق الدقيق (Flour Maturation / Aging)
عند طحن القمح وإنتاج دقيق حديث الطحن يكون هذا الدقيق "غير ناضج" أو ما يُعرف بـ "Green Flour".
السبب أن بروتينات الجلوتين تكون ما زالت لينة وضعيفة، كما أن بعض الإنزيمات (مثل الأوكسيديز) والمركبات الكبريتية (–SH) لم تستقر بعد.
مع مرور الوقت، وبتعرض الدقيق للهواء (الأكسجين)، تحدث عملية أكسدة طبيعية للبروتينات والدهون، فيزداد ترابط سلاسل الجلوتين (تحول –SH إلى روابط ثنائية الكبريت –S–S–).
النتيجة: يصبح العجين أكثر تماسكًا ومرونة وقادرًا على الاحتفاظ بالغاز → وبالتالي تتحسن جودة الخبز.
لهذا السبب كان قديمًا يتم تخزين الدقيق لأسابيع قبل استخدامه ليصبح مناسبًا للخبز.
🔹 الإضافات التي تسرّع عملية النضج (Maturing agents / Flour Improvers)
المؤكسدات (Oxidizing agents):
فيتامين C (Ascorbic Acid – E300): الأكثر شيوعًا، يعمل كمؤكسد بعد تحوله في العجين.
بيروكسيد البنزويل (Benzoyl Peroxide – E928): استُخدم قديمًا لتبييض وتعتيق الدقيق.
برومات البوتاسيوم (Potassium Bromate – E924): فعّال جدًا لكنه حُظر في معظم الدول لمخاطره الصحية.
Azodicarbonamide (E927a): مسموح في بعض الدول وممنوع في أخرى.
الإنزيمات:
مثل Glucose Oxidase → ينتج بيروكسيد الهيدروجين الذي يساعد على أكسدة وتقوية شبكة الجلوتين بسرعة.
المعالجة بالغازات المؤكسدة:
الأوزون (Ozone treatment): يُستخدم كعامل طبيعي للأكسدة والتعقيم في آن واحد.
التهوية القوية (Air exposure): تعريض الدقيق حديث الطحن للهواء المضغوط لتسريع النضج.
✅ الخلاصة:
نضج الدقيق يعني استقرار بروتيناته وإنزيماته بعد الطحن ليصبح مناسبًا للخبز.
الدقيق حديث الطحن يحتاج فترة تعتيق طبيعي (أسابيع) أو يُعالج بإضافات (مؤكسدات، إنزيمات، أوزون) لتسريع النضج وتحسين خواصه.
مرسل: الخميس سبتمبر 04, 2025 11:05 pm
الربط والعلاقة بين نقل الدقيق بالبلاور (الهواء المضغوط) وبين عملية النضج وجودة اللون :
🔹 أولاً: تأثير البلاور على نضج الدقيق
نقل الدقيق حديث الطحن باستخدام البلاور يعرّضه لكمية كبيرة من الهواء (أكسجين) أثناء التدفق.
هذا التعرض للأكسجين يسرّع إلى حد ما عملية الأكسدة الطبيعية للبروتينات (تحويل –SH إلى –S–S–) → وبالتالي يساهم في التعتيق السريع مقارنة بالتخزين الساكن.
لكن:
تأثير البلاور محدود ومؤقت، ولا يغني عن دور المؤكسدات أو فترة التخزين الكافية.
النتيجة أشبه بـ "دفعة أكسدة أولية" تساعد على بداية النضج فقط.
🔹 ثانياً: تأثير البلاور على لون الدقيق
البلاور نفسه لا يغيّر اللون بشكل مباشر، لكن:
زيادة الأكسدة أثناء النقل قد تجعل اللون أفتح قليلًا (لأن الأكسدة تُضعف نشاط إنزيم PPO المسؤول عن الاسمرار).
إذا كان خط النقل (الأنابيب – الفلاتر) غير نظيف، قد يحدث تلوث دقيق بالنخالة الناعمة أو الدست المحترق → يسبب لونًا أغمق.
الحرارة الناتجة من الاحتكاك والهواء الساخن (لو الضغط عالي جدًا) ممكن تؤثر بشكل طفيف على نشاط الإنزيمات واللون.
✅ البلاور يساعد على تسريع النضج بدرجة محدودة لأنه يعرّض الدقيق لكمية كبيرة من الأكسجين.
بالنسبة للون:
غالبًا يظل ثابتًا أو قد يصبح أفتح قليلًا مع الأكسدة.
لكن لو خط البلاور غير نظيف أو به سخونة زائدة → ممكن يغمق اللون أو تظهر به عيوب.
