Objectives of the Wheat Cleaning Section أهداف قسم تنظيف القمح
#wheat #wheatflour #cleaning
1st Cleaning Section
1. Blending of Different Grades of Wheat: Different grades of wheat may have varying characteristics, such as protein content or milling quality. Blending involves mixing different grades of wheat to achieve a desired quality or consistency in the final product.
2. Removal of Coarse Impurities: Coarse impurities, such as larger pieces of debris or foreign materials, are removed from the wheat grains. This can be done using various methods like sieving or air aspiration.
3. Removal of Dust: Dust particles present on the wheat grains are removed to ensure cleanliness and food safety. This is often achieved by passing the wheat through pneumatic or mechanical cleaning systems.
4. Removal of Ferrous Metals: The presence of ferrous metals, such as iron or steel, can be detrimental to the milling process. Magnetic separators or other metal detection systems are used to remove these metals from the wheat grains.
5. Removal of Sand and Fine Particles: Sand and fine particles are removed to prevent abrasion and damage to milling equipment. Techniques like air aspiration or sieving can be employed to separate the wheat from these materials.
6. Removal of Stones: Stones or other heavy impurities are removed to prevent damage to milling machinery and ensure the quality of the final flour. Specialized equipment like stone separators or gravity tables are used for this purpose.
7. Removal of Husk and Light Particles: The husk or outer layers of the wheat grain, as well as light particles like chaff or straw, are separated. This can be achieved through processes like winnowing or aspiration, where air is used to separate the lighter materials from the wheat.
8. Removal of Long and Round Particles: Wheat grains that are misshapen or elongated are removed as they can affect the milling process. Optical sorting machines or sieves with specific hole sizes can be used to separate the desired wheat grains from those that are irregular in shape.
9. Surface Treatment for Bacteria Count Reduction: To ensure food safety, the wheat grains may undergo surface treatment to reduce bacterial contamination. This can involve methods like washing, steam treatment, or other sanitization techniques.
10. Separation of Non-Wheat Material: Any remaining non-wheat materials, such as seeds, weed fragments, or other grains, are separated from the wheat using techniques like sieving, air aspiration, or optical sorting.
11. Removal of Wheat which is not suited for Milling Purpose: Finally, any wheat grains that are not suitable for milling, such as damaged or diseased grains, are removed from the batch to maintain the quality of the final flour product.
These steps collectively ensure that the wheat grains are cleaned, free from impurities, and properly prepared for the milling process, resulting in high-quality flour.
https://www.linkedin.com/posts/australian-technical-miller-association-inc-527287277_wheat-wheatflour-cleaning-activity-7087601109531312128-MqKy?utm_source=share&utm_medium=member_android
#القمح #دقيق_القمح #التنظيف
القسم الأول لتنظيف القمح
1. مزج درجات مختلفة من القمح:
قد يختلف خصائص الدرجات المختلفة من القمح ، مثل محتوى البروتين أو جودة الطحن. ينطوي المزج على خلط درجات مختلفة من القمح لتحقيق جودة أو اتساق مرغوب في المنتج النهائي.
2. إزالة الشوائب الكبيرة:
يتم إزالة الشوائب الكبيرة ، مثل القطع الكبيرة من الحطام أو المواد الأجنبية ، من حبوب القمح. يمكن القيام بذلك باستخدام طرق مختلفة مثل الغربلة أو التهوية بالهواء.
3. إزالة الغبار / الدست:
يتم إزالة جسيمات الغبار الموجودة على حبوب القمح لضمان النظافة والسلامة الغذائية. يتم ذلك عادة عن طريق تمرير القمح من خلال أنظمة تنظيف هوائية أو ميكانيكية.
4. إزالة المعادن الحديدية:
يمكن أن يكون وجود المعادن الحديدية مثل الحديد أو الصلب ضارًا بعملية الطحن. يتم استخدام فواصل مغناطيسية أو أنظمة كشف المعادن الأخرى لإزالة هذه المعادن من حبوب القمح.
5. إزالة الرمل والجسيمات الدقيقة:
يتم إزالة الرمل والجسيمات الدقيقة لمنع التآكل والضرر لمعدات الطحن. يمكن استخدام تقنيات مثل التهوية بالهواء أو الغربلة لفصل القمح عن هذه المواد.
6. إزالة الحجارة:
يتم إزالة الحجارة أو الشوائب الثقيلة الأخرى لمنع الضرر لآلات الطحن وضمان جودة الطحين النهائي. يتم استخدام معدات متخصصة مثل فواصل الحجارة أو الجداول الجاذبية لهذا الغرض.
7. إزالة القشرة والجسيمات الخفيفة:
يتم فصل القشرة أو الطبقات الخارجية لحبوب القمح ، بالإضافة إلى الجسيمات الخفيفة مثل القش أو القشرة. يمكن تحقيق ذلك من خلال عمليات مثل الهز أو التهوية ، حيث يتم استخدام الهواء لفصل المواد الخفيفة عن القمح.
8. إزالة الجسيمات الطويلة والدائرية:
يتم إزالة حبوب القمح التي لهاشكل غير منتظم أو مطول ، حيث يمكن أن تؤثر على عملية الطحن. يمكن استخدام آلات فرز بصرية أو غرابيل ذات أحجام فتحة محددة لفصل حبوب القمح المطلوبة عن تلك التي لها شكل غير منتظم.
9. معالجة سطحية للحد من عدد البكتيريا:
لضمان السلامة الغذائية ، قد تخضع حبوب القمح للمعالجة السطحية للحد من التلوث البكتيري. يمكن أن تشمل هذه الطرق غسل القمح ، أو معالجته بالبخار أو تقنيات تطهير أخرى.
10. فصل المواد غير القمحية:
يتم فصل أي مواد أخرى غير القمح المتبقية ، مثل البذور وشظايا الأعشاب أو الحبوب الأخرى ، عن القمح باستخدام تقنيات مثل الغربلة أو التهوية بالهواء أو الفرز البصري.
11. إزالة القمح الذي لا يصلح للغرض من الطحن:
في النهاية ، يتم إزالة أي حبوب قمح لا تصلح للطحن ، مثل الحبوب التالفة أو المصابة بالأمراض ، من الدفعة للحفاظ على جودة المنتج النهائي من الطحين.
تضمن هذه الخطوات بشكل مجتمع أن حبوب القمح تم تنظيفها وخالية من الشوائب الكبيرة ومستعدة بشكل صحيح لعملية الطحن ، مما يؤدي إلى الحصول على طحين عالي الجودة.
تم التدقيق و الترجمة
Re: Objectives of the Wheat Cleaning Section أهداف قسم تنظيف القمح
من المهم أن يتم تنظيف القمح بشكل جيد لأن الشوائب الموجودة في القمح يمكن أن تؤثر على جودة الطحين النهائي وعلى الآلات التي تستخدم في عملية الطحن. عملية تنظيف القمح تشمل العديد من الخطوات المختلفة، كما هو مذكور في الأهداف التي تم ذكرها في السؤال.
يجب ملاحظة أن تنظيف القمح ليس فقط يتم في المطاحن ولكن يتم أيضا في مزارع القمح ومناطق التخزين والنقل. ومع ذلك ، يتم التركيز بشكل أكبر على تنظيف القمح في المطاحن حيث يتم تحويله إلى طحين.
بالإضافة إلى التنظيف الأساسي للقمح ، يمكن أيضًا إجراء بعض العمليات الإضافية لتحسين جودة الطحين. على سبيل المثال ، يمكن إجراء تكييف الماء للحد من محتوى الرطوبة في القمح وتحسين عملية الطحن. كما يمكن إجراء معالجة الرغوة لتحسين خصائص العجينة.
يمكن القول أن عملية تنظيف القمح هي جزء هام من عملية إنتاج الطحين. تساعد عملية التنظيف على الحصول على طحين عالي الجودة وتقليل التكلفة التي قد تنشأ عن إصلاح الأضرار التي قد تسببها الشوائب الكبيرة في الآلات.
يمكن أن تختلف خطوات تنظيف القمح حسب المنطقة الجغرافية والمعدات المستخدمة في المطاحن. ومع ذلك ، فإن الهدف الرئيسي من عملية تنظيف القمح هو إزالة جميع الشوائب الكبيرة والصغيرة والمواد الأجنبية والحبوب التالفة من حبوب القمح.
بشكل عام ، تتضمن عملية تنظيف القمح الخطوات التالية:
1. المزج: يتم مزج درجات مختلفة من القمح لتحقيق جودة أو اتساق مرغوب في المنتج النهائي.
2. إزالة الشوائب الكبيرة: يتم إزالة الشوائب الكبيرة ، مثل القطع الكبيرة من الحطام أو المواد الأجنبية ، من حبوب القمح.
3. إزالة الغبار: يتم إزالة جسيمات الغبار الموجودة على حبوب القمح لضمان النظافة والسلامة الغذائية.
4. إزالة المعادن الحديدية: يتم استخدام فواصل مغناطيسية أو أنظمة كشف المعادن الأخرى لإزالة المعادن الحديدية من حبوب القمح.
5. إزالة الرمل والجسيمات الدقيقة: يتم إزالة الرمل والجسيمات الدقيقة لمنع التآكل والضرر لمعدات الطحن.
6. إزالة الحجارة: يتم إزالة الحجارة أو الشوائب الثقيلة الأخرى لمنع الضرر لآلات الطحن وضمان جودة الطحين النهائي.
7. إزالة القشرة والجسيمات الخفيفة: يتم فصل القشرة أو الطبقات الخارجية لحبوب القمح ، بالإضافة إلى الجسيمات الخفيفة مثل القش أو القشرة.
8. إزالة الجسيمات الطويلة والدائرية: يتم إزالة حبوب القمح التي لها شكل غير منتظم أو مطول.
9. معالجة سطحية للحد من عدد البكتيريا: يتم معالجة سطحية للحد من التلوث البكتيري.
10. فصل المواد غير القمحية: يتم فصل أي مواد أخرى غير القمح المتبقية ، مثل البذور وشظايا الأعشاب أو الحبوب الأخرى ، عن القمح.
11. إزالة القمح الذي لا يصلح للغرض من الطحن: يتم إزالة أي حبوب قمح لا تصلح للطحن ، مثل الحبوب التالفة أو المصابة بالأمراض.
عملية تنظيف القمح تساعد على ضمان جودة الطحين النهائي وتحسين كفاءة عملية الطحن وتقليل التكاليف الإضافية لإصلاح الأضرار التي يمكن أن تتسبب فيها الشوائب في الآلات. بالإضافة إلى ذلك ، يتم تحسين السلامة الغذائية من خلال إزالة الشوائب الخطرة والمواد الأجنبية. ومن المهم أن تذكر أن عملية تنظيف القمح تختلف باختلاف المناطق الجغرافية والمعدات المستخدمة في المطاحن ، ولذا فإن العمليات المحددة قد تختلف قليلاً. ولكن بشكل عام ، فإن عملية تنظيف القمح تعتبر جزءًا مهمًا من عملية إنتاج الطحين وتساعد على إنتاج طحين عالي الجودة وصحي وآمن للاستهلاك البشري.
بالإضافة إلى الخطوات التي ذكرتها سابقًا ، يمكن أيضًا تنفيذ بعض الخطوات الإضافية في عملية تنظيف القمح لتحسين جودة الطحين النهائي. بعض هذه الخطوات تشمل:
1. معالجة المياه: يمكن استخدام معالجة المياه لتحقيق توازن جيد في محتوى الرطوبة لحبوب القمح. يتم ذلك عن طريق رش الماء على حبوب القمح وبعض الضغط والحرارة لتحسين جودة الطحين النهائي.
2. فصل الشوائب: يتم فصل الشوائب الصغيرة والشوائب الخفيفة ، مثل الرمل والغبار والجسيمات الخفيفة الأخرى ، باستخدام الهواء المضغوط.
3. تعديل التدفق: يمكن ضبط تدفق حبوب القمح في مراحل مختلفة من عملية تنظيف القمح ، مما يمكن أن يؤدي إلى تحسين جودة الطحين النهائي.
4. تنظيف الأسطح: يتم تنظيف الأسطح الداخلية والخارجية للآلات المستخدمة في عملية تنظيف القمح للمحافظة على نظافة المعدات والتقليل من خطر التلوث وتلف المعدات.
5. فصل الأشياء الصلبة والسائلة: يمكن استخدام فصل الأشياء الصلبة والسائلة ، مثل الزيوت والشحوم ، في عملية تنظيف القمح لمنع تلوث الحبوب.
يتم تنفيذ كل هذه الخطوات بعناية وحرص كبير ، حيث تتأثر جودة الطحين النهائي بكل خطوة في عملية تنظيف القمح. ويجب أن يتم تنفيذ هذه الخطوات بما يتوافق مع المعايير الغذائية الصارمة واللوائح البيئية للحفاظ على سلامة الغذاء والصحة العامة.
أهداف قسم تنظيف القمح 2nd Cleaning Section - موقع زدنى علما zdny3lma https://www.millingtec.com/php/viewtopic.php?t=7254
# wheat flour # wheat # cleaning # grains
2 قسم التنظيف
# دقيق القمح # القمح # التنظيف # الحبوب
1. Tempering: is a process used in grain milling, particularly for wheat, to condition the grain for grinding. It involves adding water to the wheat kernels to increase their moisture content to a specific level before grinding. The primary purpose of tempering is to make the endosperm (the starchy part of the grain) more resilient and easier to separate from the bran and germ during milling.
1. الترطيب: هي عملية تستخدم في طحن الحبوب ، خاصة بالنسبة للقمح ، لتكييف الحبوب للطحن. يتضمن إضافة الماء إلى حبوب القمح لزيادة محتواها من الرطوبة إلى مستوى معين قبل الطحن. الغرض الأساسي من الترطيب هو جعل الاندوسبرم (الجزء النشوي من الحبوب) أكثر مرونة وأسهل في الفصل عن النخالة والجنين أثناء الطحن.
For wheat, the usual moisture content required for tempering is around 14.5%. However, if the wheat is too dry, it may not grind properly, resulting in low flour extraction rates and poor flour quality. In such cases, further water addition is needed to achieve the desired moisture level. This additional water is typically sprayed onto the wheat kernels, and they are mixed or tumbled to ensure even distribution.
بالنسبة للقمح ، يبلغ محتوى الرطوبة المعتاد المطلوب للترطيب حوالي 14.5٪. ومع ذلك ، إذا كان القمح جافا جدا ، فقد لا يطحن بشكل صحيح ، مما يؤدي إلى انخفاض معدلات استخراج الدقيق وسوء جودة الدقيق. في مثل هذه الحالات ، هناك حاجة إلى مزيد من إضافة الماء لتحقيق مستوى الرطوبة المطلوب. عادة ما يتم رش هذا الماء الإضافي على حبوب القمح ، ويتم خلطها أو تقليبها لضمان التوزيع المتساوي.
2. Scouring: Scouring involves removing the outermost layer of the wheat kernel, which is known as the bran. This process is typically done using abrasive machines that rub against the kernels, effectively scrubbing off the bran. Scouring results in a lighter-coloured flour with a finer texture.
2. الصنفرة: يتضمن التنظيف بالصنفرة إزالة الطبقة الخارجية من نواة القمح ، والتي تعرف باسم النخالة. تتم هذه العملية عادة باستخدام آلات كاشطة تحتك بالحبوب ، وتنظف النخالة بشكل فعال. ينتج عن التنظيف بالصنفرة دقيق أفتح اللون مع قوام أنعم.
