Where to Find Damaged Heat Sink in ARC Raiders
IronRune73
مشاركات: 26
اشترك في: السبت يوليو 05, 2025 8:43 am
مشاركة بواسطة IronRune73 »
What is a Damaged Heat Sink?
The Damaged Heat Sink is a rare item in ARC Raiders that can be recycled into crafting materials. It plays an important role in upgrading the Utility Station and is a valuable resource for crafting high-end items.
How Do I Get a Damaged Heat Sink?
If you're wondering where to find the Damaged Heat Sink, you're not alone. It's a rare item, and locating it can be a bit tricky, but with some persistence, you'll be able to gather it efficiently. Here are the key ways to acquire this item:
1. Scavenging
The most common method for obtaining a Damaged Heat Sink is through scavenging. You’ll need to explore different areas where you can find and loot server racks.
Server Racks are one of the primary sources of Damaged Heat Sink. You can often find these racks scattered in Technological zones. These areas have high-tech equipment and are a great place to look for crafting materials and valuable items.
2. Recycling and Salvaging
Once you have collected enough Damaged Heat Sinks, you might want to recycle them for additional crafting resources. You can recycle Damaged Heat Sinks into:
6 Metal Parts
2 Wires
Alternatively, if you're looking to salvage the item, you will receive:
3 Wires
This makes Damaged Heat Sink a versatile material for players looking to gather resources for crafting and upgrading.
3. Workshop Upgrade
The Damaged Heat Sink is also required for upgrading your Utility Station. If you’re focused on improving your workshop, you’ll need two of these items, along with other resources like Electrical Components and Snitch Scanners.
Upgrade Requirements for Utility Station 1 to Utility Station 2:
2x Damaged Heat Sink
5x Electrical Components
6x Snitch Scanners
This upgrade can help you improve your crafting abilities and access better items in the game.
Can I Buy and Sell Damaged Heat Sinks?
Yes, you can buy and sell ARC Raiders blueprints that include Damaged Heat Sinks as part of the item list. Keep an eye on the market or forums where players exchange items, as this can be a good opportunity to either sell your surplus Damaged Heat Sinks or buy them if you're in need.
Selling your Damaged Heat Sinks can be a lucrative way to make coins or acquire other rare materials, especially if you have extras that you don’t need for upgrades.
Finding Damaged Heat Sinks in ARC Raiders may take some time, but by scavenging the Technological zones, recycling, and upgrading your utility station, you'll be well on your way to accumulating this important resource. Remember to check out the player market if you're looking to buy and sell ARC Raiders blueprints or exchange materials for better equipment.
Latest Dev Blog: Arc Raiders Snap Blast Grenade: Best use and how to get
